g1 ignition troubles
northcoastcarts
Ok i had a issue of it quit running on me so i messed around had no spark so i grounded the coil better with a piece of wire it ran for a bit and then quit again. so i thought it was the coil bought a new one installed it still didnt run so i put me ground wire on one of the mounting bolts of the coil to the negative of battery. it started and made it about to the end of the campground and started sputtering blowing out a lot of smoke and popped and carried on then eventually just quit. any ideas ? is there points and condesor? any help would greatly be appreciated..thanks
OlBoy
did you ever get the problem fixed?
