G1 engine
xkcrazy
Anyone have an extra compression spring for the primary sheave?
Will cart drive without the spring in place?
thanks
Hi X,
I think what Qwik meant is that you must have the spring in order for the clutch to operate.
xkcrazy
Trying a spring from a rainbird sprinkler, cut down to size. As original is not available,
improvising becomes necessary. Will advise if works
proflow
I had my clutch all apart to clean, mill a little off the weights, & didn't have a spring either.
Mine is not the Comet clutch if that matters. So is this wrong ?
Proflow
