g1 drops down in reverse
ray j
g1 drops down in reverse.wheels bow out and rub on fenders.I did replace the king pins.It only does this in reverse,forward runs straight. Could it be in the front shocks ? thanks for response.
bonduranth
Tow in should be 1/4 inch. measure with a 4 foot sheet rock square and a square clamped on the end. Measure with the wheel on. I presume that you mean the wheel rubs in reverse and the steering turned all the way in either direction. Shocks may cause this problem but worn bushings on the a=frame is more likely. Also check the tab on the spindle to masure it has not been bent.
