ghostrider500
My cart will run about two blocks when first ran and then will just lose power. By losing power, I mean it just starts coasting with engine retarding and cycling down, cart rolls to a stop and the generator(?) is still running. I wait a second or two, push the accelerator and it will fire up and go maybe five feet and do it again....and again. If I turn off ignition, pump the accelerator and/or choke/unchoke a few times it will start and run farther before doing the shut down dance again. So I' m thinking fuel delivery issue. Am I barking up the right tree here?
If so, my next question is.. can the 5" lift I recently installed be causing this by having my motor at an increased angle causing my float to be out of adjustment(level)?
The cart had a new fuel filter and pump on it when I bought it and I didn't really run it enough to know if this issue was a preexisting condition before I redid the cart and lifted it, but I now have my suspicions
I think I will first replace my fuel line that hadn't been replaced, especially the one going from fuel pump to crankcase to rule out fuel pump problem. Good idea?
Thanks for the ideas and answers.
