Fuel Problem 86 EZGO Marathon
justwannano
My 86 EZGO Marathon has a fuel problem it runs until all the gas is out of the fuel filter. Then it dies. I can blow into the gas tank and some fuel will get to the filter (about 1/4") and it will start again. Then the same thing happens. I rebuilt the fuel pump and believe it to be correct. Fuel lines from gas tank to filter are clear and I've blown air back into the gas tank so those lines are clear. New fuel filter.
I'm not sure what to try next.
Any help is appreciated.
Bob
More than likely the crankshaft seals are bad, have tried to run it by gravity feeding it fuel?. Some guys run a low pressure electric fuel pump, its works for a while but in time it won't run at all:twocents:
