front tires rubbing
cottonman1
i have a 1997 gas club cart with 6 inch lift with 23-10.5-12 tires and the front tires rub what are my options new rims and tires or just tires thanks
You can re-drill the holes for the shock tower about 3/4" farther towards the front of the frame and remount the suspension there.
And, you can cut the frame a little right in front of the round crossmember. Just taper it off some.
\EDIT/
The frame doesn't have those after 1997, so disregard that part.
Some, but when there is a lot of weight on the cart, it will still do it. A new leaf will help a little bit, but the only way to guarantee it is to move the suspension forward.
