front rubber motor mount keeps falling off???
phoneman702
i have a 98 cc gas, with a 6" all sport lift. the rubber motor mount in front of the motor under the FNR lever, keeps falling out. it is a litle dry rotted but not bad. anybody had this problem? :wallbash:
dirtysouth
1st... Make sure there is no pre-load on the leaf springs by loosening the u-bolts while the cart is supported with a jack under the rear end housing. Just loosen the u-bolts, both driver and passenger, then re-tighten. If that don't work, then I would replace it with an OE snubber. The aftermarket ones seem to slip off. :thumbsup: If ya have any questions, call me at the shop. 866-291-5244. Ask for Steve. :usa::hattip:
phoneman702
i wondered if i i didnt have something out of whack after i put on the lift and the new springs. i will give that a try, thanks
tcrowe3
I need some help on this as well mine dry rotted and broke I have a new one how do you put the snubber on?
