forward no rev
BCGC
well, my 99 f and r switch was rebuilt, not burning up as of yet,but no reverse? forward goes like hell.went through it over and over,still nothing in reverse. the only thing i can think it might be is the wiring of the micro-switchs. i have not had the time to look at a diagram or even to test the switches, but i do know the switch itselve and all the wires going to it are right.any ideas, bcgc
Check the reverse micro switch. Also make sure the lever on the micro switch is riding on the cam like it should be...
BCGC
HRC, IF I WAS TO LOOK AT THE CART WHAT SIDE IS THE REV LEFT SIDE OR RIGHT. ARE YOU THINKING ITS BAD OR WIRED WRONG, BOTH NEW BUT YOU NEVER KNOW. THANKS AGAIN BCGC
Th reverse micro switch is on the passenger (right) side. If it's a new switch I'm thinking it's either wired wrong or the roller isn't riding on the cam like it should be. Here's a link to a wiring diagram for the Forward and reverse switch only. The switch is up side down in the diagram. MS4 is the reverse micro switch on the wiring diagram.
E-Z-GO Forward and Reverse Switch - TXT Fleet
