Forum Upgrade
I just upgraded the forum software to the latest version. I'll be doing some tweaks to get everything setup correctly. The forum may be down off and on until I get things sorted out with the new setup If you run into any problems or something that isn't working PLEASE let me know. :cool:
Link test
I had saved bookmarks for new posts and for club car electric they no longer work just FYI
Yes some of the links have changed so you'll need to change your saved bookmarks/favorites. Sorry about that but I had to do it that way so I could create a new home page that matches the forum and is mobile friendly. I'll be updating the other external pages soon but no more links should change.
To anyone that wants to answer some older questions on the forum click the arrow next to the find threads link on the top of the forum. You can view unanswered threads there. I didn't realize there was so many questions without replies. :hattip:
I rebuilt the hompage and all of the external pages today. The homepage is now the Home tab and the other pages are in the About Us Tab on top of the forum. I still have a little tweaking to do but the pages look a lot better than the old ones did. Check them out and let me know what you think. :hattip:
I just checked and you should be able to change it. What error message did you get? Were you adding or changing the link? I do believe any links will need to be https with this version. Your website can use https but it doesn't display right unless I use http?
EDIT: I just changed mine and had no problem so I'm not sure why you can't. Try again and give me the details on any error message you may get.
It gave me a message that I could not add a link I was only changing the green part and not the link
Hmm, not sure why that would happen I checked your permissions and you are set to be able to add links in your profile. I would try again and see what happens. There is a 100 character limit in profiles but I can raise it if that's what causing the problem.
There's a view counter on the bottom of all the external pages now. Here's the stats from the home page. Not to shabby for only 4 days.
Published Feb 9, 2019 | Page views 8,163 :cool:
I added a Google Search to the forum that will search this site only with Google. Seeing how most forums only allow a 4 letter minimum in the search function it makes it hard to find posts if you're searching for something using only 3 letter or less words. It's located in the Sponsor block of the forum sidebar.
