foreward/reverse swithch
410MAN
2003 clb car sometimes will only turn over, getting spark at plug and fuel. I turned the yellow thing on the switch (f / R ) around couple times and it started, ran good for 1 day then went out and no start again so I turned yellow thing again but no start.
any suggestions? thank you in advance
shadowman
the yellow knob is for maintence mode ( nuetral ) if its not set right it won,t start in forward or reverse so get the knob set right.......if cart is turning over but not starting and you have spark than its a fuel issue..................................................
