DickB
I picked up this late 80s Marathon cart from a neighbor for next to nothing. It had this hideous "body" on it, but I had some ideas on that. The seller claimed it ran, but it had no batteries so no way to tell. I took him at his word. BTW carts are new to me.
First order of business was to strip off the body and remove some additional framework that had been added to support it.
After that, I just wanted to see if it would run. The seller was not quite accurate in saying that it worked. The solenoid was bad and in fact the coil was not even wired. Battery cables were also missing. I jury rigged a test setup with a 12v battery and verified that the motor ran, on jack stands, forward and reverse.
Next was to refurbish the electrical system. It is a resistor cart. I may upgrade down the road, but for now I just wanted to get the thing running. I cleaned up and painted the resistor box and F/R switch, installed new batteries and all new cables and wiring. Cleaned up differential and checked oil. Added battery hold down clamps which were missing. New solenoid. I added a temporary floorboard, battery cover, and seats. At this point I had a running cart.
