Float sticking?
Jackace
Help!! My "Mechanic" can't seem to figure it out. Gas siphons into crank case when not running. Float sticking? (Club car) "Mechanic" says he rebuilt carburetor.
Jackace
Thank You,
"If you want something done wright you must do it yourself."
I took bowl off carburetor.Looked like speck of gasket material blocking float needle.
No more gas siphoning into crank case.
Guess I'll be getting my own hands dirty from now on.
With help from this forum.
Thanks again.
Jackace
NOW when it starts it goes strait to full throttle.
Could that be governor out of adjustment ?
rusty1
Check to see where the butterfly in the carburator is setting..... All the way open or almost closed?
Keyguy
Overworked, underpaid :o) R.I.P.
Also check to see if the throttle butterfly is even there.
I have seen 2 "swallow" the butterfly......
Jimmy B.
