FISHING
IAMCOOL
I FISH WHENEVER I CAN FIND THE TIME... AND SOMETIMES WHEN I CANT..
I fish quite a bit at the cottage. I have a 16ft Tracker with a 50hp Merc. that I use at several local lakes a 16ft pontoon with a 120lb thrust electric and a 16 ft jon boat I use at the cottage... I'm looking forward to spring so I can get at it again....
IAMCOOL
i run a bass tracker pro 16 with a 35 merc.... and today i just bought a venture 16 with a 115 hp johnson.... its fast
ubercart
I use a samll sea nymph for bass fishing and my 24ft smokercraft pontoon for crappie fishing and the boats name is topless! Thats the way I like it!!!!
IAMCOOL
i need some advice with my new boat... gpsed at 59 mph yesterday but i still had trim left... as i started up on the trim the thrust came on real strond but the front of the boat kinda felt wobbly... i feel it can reach 10 more mph but im scared cause it felt real unstable.... is there a way to correct this or do i just have to keep it at around 55.... brings a song to mind
I'd keep it at 55 or where ever you feel safe. It sounds like what your describing is called porposing. I've seen those trim tabs you can mount on the motor or the transom but I've never tried them before.
IAMCOOL
although the engine already has been supposedly bored and i just had jets put in...also someone at a johnson site suggested that i may have side to side play in the engine to steering...causing the boat nose to sway under high speed
