I will try to explain it again Motor turns over but does not crank. I take plug wire off plug and put screw driver in cap and turn over iengine and i get a spark. I put spark plug cap back on and engine turns over and cranks.
Okay your getting spark. Is the spark blue? Next thing to check is to see if your getting fuel to the carburetor. Take the gas line off at the carb and put the line in a can or bottle and crank it over and see if it's pumping gas.
