FE350 parts
Waldoweirdo
In need some serviceable parts for a FE350 (2004).
The counterbalance sleeve seized to the guide post and broke a connecting rod.
Parts I need:
1 flywheel side conrod (Part #: 1017471)
1 spacer (#: 1017502) (Thrust washer goes between crank and conrod listed above)
1 guide post (#: 1016470) (aluminum casting with 4 mounting studs low on main case)
1 oil float bracket (#: 1016510)
1 oil float assy (#: 1016494)
I believe all years of FE350 are the same for these parts and maybe FE 290 stuff will fit. If you have any let me know and I'll confirm the fit.
Thanks, Waldo
