fe-290 replacement
prafersno
Hello,
I have a 1993 CC that is making a noise like something rubbing/grinding behind the fan/flywheel.
I have a feeling it is the driver's side crank bearing.
I would like to find a full rebuild kit and if the price is right a replacement engine.
Any info would be appreciated.
Thanks, Greg
Welcome to the forum...
Did it start making the noise all at once? Maybe something got stuck in there. As far as parts go I like using genuine parts on the engines. Maybe you can find a good used engine here from someone who did a engine conversion.
BadToTheBone
Moderator
Put a ad here in the wanted section. Ill bet you can pick up a used one pretty cheap.
