I recently purchased a Fairplay Goat. Batteries bad when purchased. So, I replaced the batteries etc. No cart powers up. However, when I switch it in forward or reverse it will crawl. it even crawls after I let up on the pedal. This cart has a ACTER AC Invertor for a controller, it has a red light on the controller. Is there a way to pull a code from this? I pulled the pedal assy. and tested the potentiometer etc. and it appears to work correctly.
Something else to add is when I turn the key on the solenoid activates and stays on. on another Fairplay cart my neighbor has the solenoid activates with key but deactivates about 30 seconds later until the pedal is pressed... any help would be appreciated.
