Failing Voltage Regulator
cerbatezman
I've a 1996 gas EZGO TXT. The voltage rectifier has failed for a second time. Until I was made aware it was cooking my battery (strong smell of sulfer or sewage) I was oblivious of the seconds fail. I've decided to convert to the adjustable type that club car and others use.
I wonder if anyone else have gone this route. I'll post a followup soon.
I've a 1996 gas TXT. The voltage rectifier has failed for a second time. Until I was made aware it was cooking my battery (strong smell of sulfer or sewage) I was oblivious of the seconds fail. I've decided to convert to the adjustable type that club car and others use.
They won't fail if you buy an OEM one. $83.27 from a dealer I buy from. Also could save your ignitor from frying. Over voltage can trash it.
I wonder, Tomd, if you could stear me to an OEM ignition coil. I'm on my second Redhalk. First one quit on one side. The second has reverted to a spark so weak it won't jump the gap on a tester and is (I believe) causing the sputter and spit back through the carb on initial take-off.
