david11690
Well it seems my 06 PDS stopped today and we decided to inspect and perform the self diagnostic test and it seems I either go no codes with the FWD RVR swith in Neu or if I switch it to RVR I get 2-2 but the voltage on the battery appears to be 37.8 volts. So, upon further inspection I found the black wire leading to the black motor F2 melted about half way, it appears the wire rubbed on the solenoid nut which cut the vinyl sheathing.
What do I check next, because once the repair was made to the F2 wire the state of charge meter reads full, and the FWD button pushed along with the pedal does not move the wheels, I am hoping the solenoid, but the black wire leads directly to the motor.
