Resource icon
EZGO Workhorse ST-350 Service Manual
Kit
Thank you for the service manual, it downloaded great, however no switch diagram, I found a picture of the back of the switch and it shows two hot in positions, B and B1, so i'm probably wired correctly since everything works fine. I will start to diagnose the voltage reg for the charging problem, just felt that I needed to know if the switch was right first. Thank you again for your help!
