EZGO Workhorse Gas Cart Won't Start
dosment
2003 EZGO Workhorse gas cart won't start. New carburetor, new battery and checked all the usual. Pull out the choke and it turns over good but will not take off. Kids playing on it hit a tree. Can it be an electrical problem. Will take off once in a while. 2003 workhorse 1200 glx
dirtysouth
Check fuel filter and fuel line. Also check the line from fuel pump to crankcase. Have you checked for spark at the spark plugs?
Also put your hand over carb opening and se if it starts to run or pulls fuel up into carb throat
dosment
Filter and fuel lines replaced. Will check line to crankcase. Spark and plugs are good. Will try the carb deal. Thanks alot
dirtysouth
Have you pulled the line from carb and turned over engine to make sure it's pumping fuel?
Pretty common for the pick up tube in gas tank to fall off. Tap carb bowl with handle of hammer or screwdriver, might break needle loose from seat.:twocents:
