EZGO With No Spark
wtherrin
I am pulling my hair out over a 2001 EZGO TXT Gas with no spark. Replaced bad engine with rebuilt engine and had spark before replacing engine but no spark now. Have replaced pulsar with new, tried different air gaps on pulsar, tried a new ignitor, replaced coil, sanded off all ground points, checked all connections, replaced some wires that I thought might be questionable, new plugs, checked for spark with spark checker, have rechecked all connections about 25 times and still no spark. Engine turns over fine but here is what I have. Pulsar ohms out 18 ohms, when engine turning over the most ac voltage I can get is about .45 volts from pulsar. checked voltage on primary side of coil and get about 10.9 when cranking from + (red wire of coil) to battery ground (-). Get 0 voltage from + to - on coil primary. Voltage at battery across terminals reads 12.6 volts. Can anyone help? The pulsar voltage seems abit low to me but I can't get any more from it and have the air gap at about .004. The more gap I set (up to .032) the weaker the pulsar voltage. I'm wondering if something has happened to the flywheel. HELP I'm having nightmares over this. Even called a tech from another shop over to look and he is stumped. Thanks.
There is nothing on the flywheel to go bad or change. Are we sure the ground cable from the engine to frame is connected?
Is there power to the igniter?
wtherrin
Yes I've checked all grounds, sanded connection points and even run extra ground from bat neg to engine.. Orange and white as well as red to pulsar are connected to power side of solenoid coil. Powers when engine turns over
I’m in the same boat and my pulsar is the same ohms and I can’t get spark to save my life. Where does the solid orange wire out of the igniter go ?
Rstaley
This is the diagram that have been using for a long time. Its on my website if you follow my signature link. Take the color of the wires with a grain of salt. They can vary.
