rbdaves
‘99 EZGO GAS 295cc Robin engine.
New engine, no spark. I checked the coil and pulser and they were ok according to the user manual. I shined up all the grounding points on the cart and checked them and they were all good. I had to run two wires around the ignitor plug due to broken wires. I then checked all continuity and the wires to the pulser and coil now are continuous. The only thing I could do with the ignitor was to be sure it was grounded and it is. I put a test light between the coil primary `lead and battery ground and got a solid light when cranking. Got the same thing on the other lead. This doesn’t seem right. Is the ignitor bad?
I would also like to find the connector that slides into the ignitor plug. Anyone know where I might find one of these? ditto for the slide on plug for pulser. The original plugs look dirty and suspicious.
