ezgo winch mount
labrian
been wanting too add a winch 2 a 2002 txt found a brush guard with winch mount called the beast it bolts on where the front roof supports bolt on. would this be strong enough or should i fab somthing off the front axle
dirtysouth
The axle on an ezgo is a better location than the top support mnts. Look under the cowl and you will see it is thin channel and there is no bracing at all for any downward forces.
labrian
yea i looked at it there aint much bracing wouldnt last long in the mud bogs around here in north fla
