sorry, it been busy up here in new england. the steering wheel will move ,but the tires don't turn. looks like it may be the steering rack........but forget that. i have a bigger problem. a guy up here has a 1999 ezgo txt dcs cart lifted with an alltrax dcx controller with a stock 36 volt motor. when key is off the resistor get warm. took a closer look and noticed it was burn up. then when you turn the key to on and switch from tow to run the controll fills up with a nice white smoke! so i ordered a new controller/ selenoid and resistor. anything else you guy think i need? i think he try'd to use a 4hp or a 6hp motor with this controller. now he knows better. even thu the old contoller say it right on it.
so just need to replace it.
