EZGO TXT Golf Cart Reverse problem!
hos
Just picked up an 02 TXT.
You can barely get the gear lever into reverse or out of forward. Feels like you're going to break the lever when switching and you can tell it's putting a lot of tension on the front panel. Is there an adjustment on the cable that takes care of that or something else going on inside the differential? Searched the boards and did not see anything like it may be a typical problem.
Welcome to Cartaholics and congrats on the new cart.
The shift cables are adjustable and may be your problem. It's possible you could have a bad cable also. Check the bottom of this post for instructions on adjusting the shift cable. Let us know if you have more questions and if this was the problem.
EZGO Gas Golf Cart Routine Maintenance
