HotRodCarts submitted a new resource:
EZGO TXT Electric Golf Cart Wiring Diagram - Series - EZGO TXT Wiring Diagram Series Golf Cart
Read more about this resource...
Note:
E-Z-GO used different Curtis controllers on EZGO TXT Series Golf Carts, controllers with and without the A2 terminal we're used. The A2 terminal was used for "Plug Braking" and EZGO stopped using it at some point.
Here's the difference in the wiring on E-Z-GO TXT Golf Carts With an A2 Terminal On the Controller and Without an A2 Terminal:
E-Z-GO golf carts that came from the factory without the A2 terminal on the controller have the cable from the A2 terminal on the motor connected to the "C" terminal on the forward and reverse switch.
E-Z-GO golf carts that came from the factory with the A2 terminal on the controller have the cable from A2 terminal on the motor connected to the A2 terminal on the controller and a separate cable connected from the A2 terminal on the controller to the "C" terminal on the forward and reverse switch.
If the 4 terminal controller is replaced with a 3 terminal controller the two cables can be bolted together to make the cable long enough to reach from A2 on the motor to the forward and reverse switch. Or a new longer cables is needed to reach from the F/R switch to the motor.
The rest of the wiring will be the same as shown on the wiring diagram.
