EZGO TXT Electric Golf Cart Motor Runs But Won't Move
dallicis
We have a 2000 EZGO TXT electric golf cart. We were using it to pull a small trailer with some limbs and brush on it. Now it won't move forward or in reverse, the motor runs but its not transfering power and isn't moving. Kinda like a car thats clutch is gone in. I need help figureing out what part I need. Can anyone help me or point me to a diagram that show the parts?
dirtysouth
One of your wheel hubs is stripped out. Raise the cart up, release the brake and turn the rear wheels. You will feel the stripped one, it'll probably have a wobble to it. Welcome to the forum. :hattip:
Buying a factory replacement hub is money well spent, most of the aftermarket hub/drums are poor quality :twocents:
GMiller
That is what has happened to me. K200 model. Can I use a cheaper hub? Do I just need to replace the hub?
I think I'd rather have a new OEM EZGO hub. The only time I've seen the factory hubs strip is if the castle nuts wasn't tight enough or the splines on the axle were bad.
