EZGO TXT Battery Draw at Rest
Patrick L
Early 2001 EZGO 36 volt series TXT.
How much battery draw should there be when at rest ?
I guess there will be some just because of the solenoid resistor [ which i don't understand why its there]
Patrick L
Thanks for the reply.
I think I'll check to see how much of draw there is. I don't like a spark when attaching the battery terminals. Plus I don't like knowing there is a draw when the cart isn't being used. I installed a primary disconnect just for a bit of a theft deterrent, I may install a secondary [heavy wire] disconnect.
