LILT79
Hows it going fellow carters. I'm new here and hopefully I can get some help or someone can point me in the right direction. Thank you ahead of time. I have been working on an EZGO TXT with a 6 inch lift, a HPEV AC drive setup and rear disk brakes with 2" spacers. we built this cart about three years ago and has been running great until last week when it shredded the outer driver side splines on the rear axle. We replaced the outer bearings on both sides and two days later it came back with the cotter pin broken and axle nut loose. tightened the nut put a new cotter pin and three days later it is back with the same problem. It sounds like something is binding but everything looked fine and turns smoothly on the jack stands I will probably change the whole rearend just to get the guy rolling again but would like to know if anybody has some input on this problem
