Our golf cart only pulsates when putting in forward or reverse. Any ideas? Batteries all test 6 volts plus, changed the solenoid and changed all the battery cables and cleaned the other contacts. Thank you for any help.
You have a voltage problem, How old are the batteries? 32 volts is the minimum for the cart to run correctly, i would suspect bad batteries or the charger is not fully charging them.
We replaced two of the batteries last year and the other ones are about 3 years old. We charge it until the light stays solid green and it says it’s 36 when we do multi meter. When I check each one they are 6.
Replacing only some of the batteries will reduce the life of the entire pack as it creates a charging imbalance. You'll need to replace all 6 batteries, as already stated your voltage is way too low.
