EZGO RXV Stopped Running
gherbert
I have a 2009 EZGO RXV that stopped running. When I put the cart in reverse, the alarm sounds and the solenoid clicks, but when I press the accelerator nothing happens. When I put the cart in forward I hear the solenoid click and the motor engage. When I press the accelerator the motor tries to go (I can feel a vibration) but it does not move. Has anyone experienced this issue?
Patrick L
You feel a vibration ? Can you hear or feel the motor running ? If so, you may have a rear drive hub issue.
gherbert
Update: I tested the batteries and one of them was very low. After charging the cart is running normal. The batteries are going on 6 years old (US battery). What does everyone recommend as far as battery replacement?
