EZGO RXV Carburetor Adjustment
mikerose
EZGO RXV with Kawasaki engine. When I press gas pedal the engine turns over a good while before it ignites and goes. If i pull the choke, it will ignite immediately. Wven when engine is warm the motor will spin for a second or 2 before starting. Is this normal or is there an adjustment on the carburetor? thanks
The carbs on golf carts are set so lean in order to pass CA emissions (no adjustment) it makes them cold blooded to start with, and then reformulated/ethanol added fuel makes them start hard. I run the best gas i can buy and add 1oz of seaform to every gal of gas.
Its works for me:twocents:
