EZGO Puking Oil Into Breather
country
Active Member
I'm working on 1996 EZGO 2 cylinder and its puking oil back into the breather. I'm thinking really bad blow by but there is a tin cover at the motor the blow by tube comes out of. My question is what's behind this and am I right to assume that it's got a stuck oil ring?
My first guess is it has too much oil in it, gas mixed in the oil? is the cart lifted? there is nothing behind the breather cover besides the reed plate and block cavity.
country
Active Member
so it does have a reed behind that cover I haven't gotten I to the motor it runs trying to keep it running for a guy and yes its lifted with 6" Jake's after running puking slowed down but still puking a little
it has too much oil in it, with a 6" lift the reading on the dipstick is off. need to drain the oil and add 1.5 quarts then check the dipstick, the oil level on the stick is the new full line. Scribe or file the new line.
