EZGO Predator Conversion Lunges
HHStang
EZGO with Predator engine conversion lunges. I'm not sure if I have a clutch issue, or which clutch it is, or if it is a belt problem, or....
Here is what happens: (1) Cannot start in gear or it moves (2) If I start in neutral and put in gear, it stalls, chirps tires, etc. (3) When it runs and I try to brake to stop, it stalls. The engine runs and idles great, its a drivetrain issue. Help please and thank you!
HHStang
Thanks! That seems to be exactly what it is. I took an old belt I had and the problem is gone. My new (but really older) is what belt to use. The old one is too narrow and breaks. It is 44 5/16 long, but only 3/4 inch wide (TR28437). The belt that I had on creating this problem is an HP2031 that measures 49 long by 1.18 wide. I needed the extra length to get the belt on and because it rode higher in the primary clutch. The wider belt doesn't have the V like the narrower one. I'm lost. Any suggestions and THANK YOU!
