I've purchased my first cart, a 2004 EZ Go TXT PDS. It's powered by three deep cycle marine batteries (36V).
I've played with the different performance plugs and it seems to be performing fine.
I'm afraid that it might not have enough power for a monster hill I need to climb (paved, maybe 0.25 miles, 10-15 degree grade).
So, I'm starting to think about upgrades.
It seems that an AC conversion is the top of the line, with the Navitas TAC controller. While I'm capable of installing that myself, that's a major expense. Plus, this is not going to be a frequently used "suburban scooter". So what are the intermediate upgrade paths?
Is there a benefit to just upgrading the controller to a Navitas TSX over the stock?
After that, it seems that I need to go to 48V DC, with new motor, new solenoid, another battery, new charger, new charging port, and, new charge meter.
I think the 48V conversion cost would be rather close to the AC conversion?
....It seems there is little actual performance data published on these different options. I know it can depend on a lot of things, but it would be helpful if someone took a cart, demonstrated performance with a specific load, then re-tested with each different configuration...
Does anyone here have the experience they can share?
Thank you!
Thank you!
