anoymouse
OK, The lights are not working my EZGO Marathon. I found this wire loom that runs from the rear lights into the fuse block on the right rear fender. There is no working horn, headlights or rear lights. I have determined that this loom is independent of anything having todo with the drive system and must be for the auxiliary system? There are about 6 wires pop out of the main end of the loom and I can tell two went to the light switch at one time and another larger one was on POS terminal which I removed and the cart still drives fine.
Can someone confirm this hard loom is 100% for aux systems (lighting?) and has nothing todo with the drive system?
I'm prob going to trace it all out, remove it and start over with the way I understand the light up the system. Just need some reassurance I'm on the right path. I've found some schematics out there for the drive system and nothing in the loom seems to apply.
