EZGO Golf Cart Got Wet and Only Goes Full Speed
Gardneral
My 1999 EZGO golf cart got pretty wet in a recent tropical storm. Now it goes full speed only in reverse. In forward it only engages a a point just past the click with the microswitch. If you put the accelerator to the floor nothing happens. In forward it has one speed only if you can hold the pedal to the exact spot where it engages. Suggestions. I have cleaned terminals, spade connections, f&R cam.
Welcome to the forum.
More than likely it's the ITS under the floor panel that got wet. If you're still having problems now that the cart had a chance to dry out you can pull the floor mat up on the drivers side and take the cover off the ITS box and blow it out.
