Let off the gas pedalWhen it?
Yes, yes it's on. I don't live here, I do other things to. Just seeing if there is a fix to my scaring the dogs and neighbors.Hello hello. Tap tap is this thing on?
Waiting for me also? Here but no popcorn. Cart backfires when let off gas pedal. Not Everytime, but at least 3 in 10.
This is possible. Make sure the butterfly is fully closing when you let up on the gas pedal. Also make sure when you start to press the pedal there is a slight delay before the butterfly starts to open. When you barley press the pedal the butterfly should remain closed.The throttle cable probably needs to be adjusted.
99What year is your ezgo?
