EZGO Gas Golf Cart Starter Won't Turn Engine Over
donz
I have an EZGO gas powered golf cart and the starter won't turn the engine over. The battery tests good. Will do nothing when accelerator pedal is depressed. Fuse at relay switch good. Can jump relay and will crank, but no throttle response. Can hear micro switch under floor panel click when accelerator pedal is depressed. Any help would be greatly welcome.
divot61
what year is the cart? is there juice at the micro switch, sounds like the micro is stopping the starter/generator from engageing, check ALL connections. micros are pennies
donz
Have checked micro switch. When lever released has flow through it. Dont know year. How do you tell? Micro switch has wire from relay going in and coming out goes through another micro switch then to back up beeper, then back to ground. Dont understand that, but theres alot on this generator system i dont understand.
