EZGO forward & Reverse
ramehrer
Hi, I have an electric EZGO and on the sticker on the passenger side says G202 & 1503098. Realized by reading posts that this is really important and didn't even know the sticker was there!
Ok, when I put the cart in forward, or reverse, it doesn't always move. If I fiddle with it by going back and forth fron neutral it will all of a sudden work.
I am guessing this will only get worse.
I live on a little island off Honduras and want to order the right parts before it quits all together.
Any suggestions?
Thank you very much
The F&R is beside the drivers leg and in the battery compartment there is a metal rod that goes over to the right side of the compartment where the switches are.
Thanks for trying to help !!!!
Check all the cables connected to the F&R switch. Usually the problem your having is caused by bad contact studs in the switch. You'll have to take the switch apart to check/replace them...
Can anyone tell me what year and model my golf cart is by the codes in the passenger glove box? G202 & 1503098
Thank you
