The replacement engine came in and I am in the process of removing the old one. I am down to the last bolts securing the block. Question, what's the easiest way to get the starter out of the way. I am concerned if I wedge the retaining clip that is on the tensioning bolt I won't be able to get it back on. Am I correct that there are four bolts securing the block, two on each side. The bolts holding the skid plat on the bottom don't screw into the block do they? Is it necessary to thake the skid plate off?
1995 ezgo 295
1995 ezgo 295
