EZGO Electric
jamiewilson
Cart will go when i use a jumper from red wire on the f/r switch to the hot post on the batteries. What could be the problem? when jumped, everthing works, turn key switch on and mash ped and go! If i disconnect jumper i have nothing.
The reed switch is bad in the charger receptacle on the cart. It keeps the cart from moving when the charger is plugged in. A lot of guys just bypass them like you have done when they go bad.
jamiewilson
I think you very much for your help, I figured out how to make it go, I just didnt know what I was bypassing to make it go. So I think you very much.
