EZGO differential slipping
Welcome to the forum.
More than likely a stripped hub. Pull the dust caps off of the rear axles and see if the axles are turning. If they are you have a stripped hub. If the axles aren't turing it's probably the motor coupler.
rhgc
is the cart a series, pds, dcs (or just tell us where the forward and reverse switch is..on the body or a push button) What is the battery voltage, what year is the cart
JRay
Thanks for reporting back, glad you got it going,
