Hi, Hope I can get some help. I just got a 96 EZGO DCS golf cart that does not run and not sure what the other person done trying to get it going. What I do know is the the A1 spade terminal on the controller was bad so I was able to get a good used controller from a local shop. I put a set of New batteries in it and am getting nothing when I hit the accelerator pedal. No click at the solenoid. So I replaced the Solenoid and still no click. After digging into it further I found that the white and red wires at the Reed switch was broken in the Charging port. I was told to tie the red and white wire together to just bypass the Reed switch. Still no clicking at the Solenoid. I am not sure where to go at this point. Any advice is appreciated.
Thanks, John
Thanks, John
