EZGO Backfires Through the Carburetor
SirMiker
I have a 2000 EZGO Workhorse 350cc. It backfires through the carburetor. I have 175 lb compression The timing is correct.I adjusted the valves at .006. new plugs. I don`t know what else yo try. I need help
Is this all the time or deceleration
Timing, valves, and advance would be my first choice
SirMiker
Checked all of those things. No difference. Gave up and took it a repair shop,waiting for answer. Will let you know when it is fixed. Thanks Mike
SirMiker
Got the cart back, they checked all the things I did and came up with the same as I did.they put a new coil on it it stopped backfiring. It pops once and awhile through the exhaust sometimes when starting. the told me if it gets worse try a new carb. Thanks for all your help Mike
