I want to put the Fwd/Rev switch on the dash. I removed all the wiring, Controller, Selenoid, Fwd/Rev mechanism including the mechanical arm on the entire 36 Volt series Cart. I have full replacement parts for converting to a 48 Volt system with a Navitas AC Motor.
I can't figure out how to wire the switch, it appears the wire harness I bought EZGO OEM TXT48 harness (need for AC conversion on series and PDS) is I think set up for in the body behind the knee.
I have the Curtis SW 180 solenoid and Ezgo 48V fwd/Rev switch 2003 and up replacement part 74323G01(it's for the dash). I also have Navitas 600 amp Tac2 AC controller with Bluetooth.
I provided pictures of the solenoid, switch and the wire harness along with three wires Green, Orange and Grey.
I can't find info on this that is a series cart. I appreciate anyone who can explain how to wire the whole F/R switch from the dash to the solenoid and not sure if the controller is involved.
