SgtBryan86
Hello all. I’ve got issues on troubleshooting this PDS cart. Don’t know the exact year, data plate has been removed. Tried running diagnostic mode, and all I get is the confirmation beep. I have a new motor, key switch, and F/R switch installed. Batteries are less than a year old Rockets.
Here’s where I run into problems in the troubleshooting area:
CHECKING CONTROLLER INPUT
Connect (-) probe to B- terminal. Connect (+) probe to B+ terminal.
The reading should indicate approx. 0 volts with the resistor REMOVED and the pedal not pressed in the last 15-30 minutes.
~ I have pack voltage at those terminals.~
CHECKING CONTROLLER OUTPUT
Slowly depress accelerator pedal until the solenoid engages. Watch the voltmeter.
The reading should show the battery pack voltage. Now slowly depress the pedal and watch the reading, it should go down to nearly 0 volts.
~Depressing pedal, I have pack power when solenoid clicks, then only drops to around 33 volts with pedal to the floor before it goes right back up to pack power.~
I’d appreciate any advice anyone can give.
