EZGO 295cc Compression
bunmcgee
Hey guys, anyone have an estimate on how much the cranking compression should be on a 1994 EZGO 295cc engine? I ran a check cold and came up with 60psi on both cylinders, good or bad? Thanks appreciate the help.
yep, 155 is about the bottom line with those
did ya check it with the throttle wide open? have you set the clearance on the valves.
bunmcgee
I did set the valves beforehand, but didn't open the butterfly. This kart belongs to a neighbor and I was just lending a hand. I'll try again with the carb open and then pass along the bad news. Thanks for the help.
