Looking for a small lift for a ezgo, 2001 1/2. 2 inch maybe 3 inch. What would be best?
M mit374 New Member Mar 9, 2012 #1 Looking for a small lift for a ezgo, 2001 1/2. 2 inch maybe 3 inch. What would be best?
Pimp Daddy Cartaholic - R.I.P. Mar 9, 2012 #2 to Cartaholics!!! Usually the size tires you plan to use dictates how much lift you install.
T TDAWG Member Mar 9, 2012 #3 EZ-GO does make a 2" lift. It is designed to run 20" tires. It is not cheap but it is well made.
M mit374 New Member Mar 9, 2012 #4 Thank-you. This kit looks like the lift is in the springs? Which would be OK, one other ?. If I just put heavy duty springs on rear, adding a flip seat, three leaf or four. Thanks
